GOT IT!!!!
Old Oct 5, 2006 | 07:37 PM
rtboy's Avatar
Default GOT IT!!!!
Thanks guys I was riding my 2006 polaris sportsman 700EFI and it is awsome. I have 1 problem Tuesday I was riding it was about 80 degress and I smelt something burning. I looked by the exhaust and the plastic was melting!! I was very mad. I am wondering if the 500 and 800 melted only I thought the 700 did not melt? So I called my dealer and they said I could order a heat sheild from moose. So is the shield good. And will it still melt when I put the moose heat shield on? Other than that thanks so much. When I fix this problem it will be fine. And the fuel gage works good to.
THANKS, RTBOY
Old Oct 5, 2006 | 07:41 PM
ncriderforks's Avatar
Default GOT IT!!!!
That has been an issue. Your dealer should be able to get you some warrenty help if they will take the time. You can beef up the heat tape and shim the floorboard up bout 1/4 of an inch and that will help the air pass through it better. It only gets hot enough when you are going at slower speeds and air is not passing through fast enough to get rid of the heat buildup.
Old Oct 5, 2006 | 07:46 PM
rtboy's Avatar
Default GOT IT!!!!
Is the heat shield going to be enough and the heat tape?
Old Oct 5, 2006 | 07:59 PM
Default GOT IT!!!!
Friend put the 800 pipe and the polaris 800 heat shield on his. No problems as of yet. We did go ahead and put some heat tape on the plastic just in case.
Old Oct 5, 2006 | 08:37 PM
jampg's Avatar
Default GOT IT!!!!
Guys,
What is the moose heat shield? I have an 800 X2 coming in December. Do I need this stuff?
confused;
Old Oct 5, 2006 | 09:22 PM
rtboy's Avatar
Default GOT IT!!!!
Originally posted by: jampg
Guys,
confused;
I should have listen. A moose heat shield is on the exhaust to prevent the plastic from melting. I would get it just in case.
rtboy's Avatar
Default GOT IT!!!!
where can you get heat tape?
Old Oct 5, 2006 | 09:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default GOT IT!!!!
the melting issue is not on all the models? i have an 06 w/over 600 miles and a couple of overheats w/ no melting isues. they supposely fixed this issue w/ the 06's but i guess you never know.
Old Oct 6, 2006 | 06:30 PM
800TwinEFI's Avatar
Default GOT IT!!!!
This does seem to be a fairly common problem. I have almost 500 miles on my 06 and no melted plastic yet. It's got heated up pretty good a couple of times too. Seems like it happens @ over 500 miles for some reason? We will see if my luck holds up when the snow flies and I start plowing. All the quads I have had get REAL hot then.
Old Oct 6, 2006 | 06:46 PM
rtboy's Avatar
Default GOT IT!!!!
I got the heat shield and some new heat tape. It is fine now.
