one tire spins
Old Oct 6, 2006 | 01:32 AM
magnumLover's Avatar
Default one tire spins
on my 2000 polaris magnum 325 i was out riding and something felt wierd so i stopped and found out one tire was spinning, the axle is spinning but not that part that attaches it to the tire, so i took the tire off and tightened the bolt that this is connecting to, it got a bit tighter but when i hold the fround break and spin the tire on gravel , still stopps spining.
its hard to explain because i dont kno what the parts are called exactly, so if u need to ask questions, that would be fine[img]i/expressions/face-icon-small-tongue.gif[/img]
Simonthis is wut its like
Old Oct 6, 2006 | 07:16 AM
MOUNTAINEERRIDER's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]Magnum Lover..What you need is part# 5131649..rear hub...When you replace the hub be sure you put the washers back on properly..One is cone shaped to help keep tension on the hub...This is a very easy job to change..Torque to 100 ft. lbs..
Old Oct 6, 2006 | 11:13 AM
ok thanks alot, but i dont have a torque rench, should i just tighten it real tight? thanks u releave me alot.
Simon
Old Oct 6, 2006 | 12:18 PM
That should work just fine.Just tighten it as tight as you can get it and it will be ok..
Old Oct 6, 2006 | 07:04 PM
ok thanks for the help.
Old Oct 6, 2006 | 07:28 PM
ok wait!!!! I CANT GET THAT DARN HUB OFF! lol help !! thanks [img]i/expressions/face-icon-small-happy.gif[/img]
Simon
Old Oct 6, 2006 | 08:15 PM
Magnum Lover...Once you remove the axle nut the hub should slid off...It is either a 1 1/4 or 1 1/8 nut...That is all that holds the hub on...
Old Oct 6, 2006 | 08:17 PM
im confused, is the axle nut on the verry end of the axle? ahhh
Old Oct 6, 2006 | 08:25 PM
mine sure doesnt slide off it comes out about quartor inch then it wont budge
Old Oct 6, 2006 | 11:58 PM
Speeddrive1's Avatar
Might have to use a BFH on it.
