one tire spins
Old Oct 8, 2006 | 06:23 PM
  #21
Speeddrive1's Avatar
Default one tire spins
yep!
Old Oct 9, 2006 | 06:29 PM
  #22
magnumLover's Avatar
OKAY THIS IS ENOUGH!
i used a pulling device, and OMG it didnt come off , this is getting rediculis, any ideas on how i can get this stuborn thing off?
Old Oct 10, 2006 | 06:19 AM
  #23
My guess, the splines are so messed up that it may never come apart. Can you get the axle out w/o removing the hub. Is the bad hub on the same side as the chain or brake? If you can get the axle out, then you can put it in a press and press it off or torch it off.
Old Oct 10, 2006 | 11:44 PM
  #24
its not on the side with the break, and i was wondering , is the axle as easy to get off by just sliding it off when all the hubs and tires and the break is taken off?
Old Oct 11, 2006 | 03:23 AM
  #25
Yoshiequipped's Avatar
there may be a lockin ring on the end of that axel, i dont know anything about polaris eaxcept i dont like them but on honda sport quads there is a ring that fits in a groove cut into the axel and you have to pop it out in order to get the axel out. but the stripped splines come from the axel nut not being tightened and riding it stripped the splines. but the hub should be made out of a softer metal than the axel to allow that to happen so it will strip the hub and not the axel cause the hub is much cheaper and easier to replace than the whole kit and kaboodle.
Old Oct 11, 2006 | 12:00 PM
  #26
BigBlueScrammy's Avatar
I would try cutting it off with a hack saw or cut off wheel.
Old Oct 12, 2006 | 09:56 AM
  #27
sonOFoldmanmoses's Avatar
magnumlover.. i am very smart with fixing polaris AWD systems. PM me ur number and we'll get it fixed that day
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
fd24
Jan 16, 2019 08:59 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
