400 CC CLUTCH KITS
Old Oct 6, 2006 | 06:47 PM
fixit's Avatar
Default 400 CC CLUTCH KITS
Hey, since its friday afternoon and were all busy with work before a long weekend, I need some advice on a clutch kit. I have a 97 400 scrambler that needs clutch work. I not sure to buy new or rebuild. All the kits I have seen just seem to replace the cams and springs. I need new bolts teflon wear pads and maybe some more bolts that I have never seen. Has any one ever had to rebuild ran into this or what is the best option. thanks
Old Oct 6, 2006 | 07:45 PM
ftwflh's Avatar
If you like the way it runs then just take the clutches off and take them to a shop to get new buttons and bushings>May need new shift weights but they wear out too.
The "clutch kits" are for performance with a good clutch.
Steeldon
Sep 9, 2015 09:38 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Brandon400
Sep 7, 2015 12:20 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
