clutch or tranny problem?
Old Oct 6, 2006 | 07:36 PM
pilsner67's Avatar
Default clutch or tranny problem?
I have a 2000 325 magnum 4*4. Had since new. Just put new engine in it and was driving it when the belt broke. Going fast down the road when it happened.
I baught a new belt and was driving it when it would seem that the quad would jump forward at times ( good pick up) and then it wouldn't .
Then it would not reach top end in speed.
I bought a ne clutch spring , bushings, buttons,bearings etc. ( needed it).
After all that work it seemed that the clutch was in new shape but i am still experienceing the speed problem.
the Quad revs up fine.Just no speed. Tried bioth High and Low same thing just high revs but low speed.
It seems to have power off the start and in reverse just no speed.
coulod this be a tranny problem?
any help would be appreciated.
pil
Old Oct 6, 2006 | 07:41 PM
ftwflh's Avatar
Secondary clutch needs work
Old Oct 6, 2006 | 07:45 PM
pilsner67's Avatar
secondary clutch?
is that the driven clutch?
thanks for the reply
Old Oct 6, 2006 | 08:04 PM
ftwflh's Avatar
Sounds like the button ramps or secondary spring is broken.Yes it is the driven clutch.
Old Oct 6, 2006 | 09:04 PM
pilsner67's Avatar
thanks a lot for the reply
I guess I'll be tearing that apart now.
Thanks again for the fast reply
take care and i'll let you know how I make out
Pil
Old Oct 7, 2006 | 03:43 PM
pilsner67's Avatar
you were right.
it was the button ramps ( worn)
ordered new parts should be in in couple of days.
thanks for the help
pil
Old Oct 12, 2006 | 11:09 PM
pilsner67's Avatar
got it back together and it solved the problem.
thanks for the help.
does the spring sit in the 1-3 position or the 2-2 i've read both.
does anyone know what the factory setting is?
polaris 325 magnum 4*4
thanks a lot
pil
Old Oct 12, 2006 | 11:22 PM
ftwflh's Avatar
I would go with the 2-2 for the best backshift.
skinnyr6
Aug 25, 2023 02:18 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
honda71
Jul 8, 2015 02:13 AM
