scrambler knock sound
i just bought a 95 4x4 400 Scrambler, when it is at low idle there is an aparent knocking sound. Rev it up alittle bit and it kind of goes away. Hard to pin point where in motor it is coming from. I revs up and runs fine. Carb needs to be cleaned, but it runs good. Wondering if anyone might have a idea on the knocking noise i'm hearing. Thanks
If you can pull the front clutch off and start it and if it quits you need a new clutch or to rebuild this one.
exmotocrosser
Sep 13, 2019 06:12 AM
