Need help quick scrammy guys
I'm suppose to go riding in just a couple hours so I go out and check the oil gas up the machine pull the choke and crank the key. Everything is going fine, engine turning over as normal and then everything just went dead. No power anywhere. Is there a fuse or a breaker somewhere that may have blown. The machine hasn't been started in a month or so but I put everything away just as normal. Funny I was just boasting about not having any problems outa this machine.
Okay I went out and fiddled with it while I was waiting for a response and it was just a loose battery connection. Fired right up. I knew it wouldn't let me down. While I got your attention though I have no tail light. Brake light works just no tail light. It used to stay on all the time now it dosn't come on at all.
well i guess i dont to check the battery then. lol. did you see if the bulb is burned out. start there and work backwards checking connections.
Yes it was the bulb. I guess I should have checked that, huh. I thought if the brake light was working then it couldn't be the bulb. I didn't realize there was two filliments(sp) inside the bulb. Thank you for the help. You don't know anything about Raptors do you? It won't start either. Started fine then quit when I backed the choke off now it won't start at all. Oh well, heres another for those Yammy guys that are bashing Polaris. Scrammy's runnin like a top and the Rappy's broke.
bzdok1234
30
Feb 23, 2016 01:55 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
