2000 explorer 400
Old Oct 22, 2006 | 01:36 AM
400twostroke's Avatar
Default 2000 explorer 400
Hey everyone, I just bought a 2000 explorer 400 and I think the clutch is setup for sea level. I live at about 6000FT so I was wondering what spring and weights I should put in it to get it's full potential?
Thanks!
Old Oct 22, 2006 | 01:11 PM
anybody?
Old Oct 22, 2006 | 01:36 PM
ftwflh's Avatar
Not sure what weights are stock in yours but try going up 2-4 grams.
Old Oct 23, 2006 | 07:23 PM
I always thought that when you went from low elevation to high elevation you were suppose to lighten the weights and stiffen the spring? Does anybody know what jet,weights and primary springs come in the explorer 400?
Thanks
Kris
Old Oct 24, 2006 | 08:03 AM
ftwflh's Avatar
I had it backwards you are right you do lighten the higher you go.
Old Oct 24, 2006 | 09:12 PM
Just incase anybody wants to know I found out what you need for the 400 at high elevations.
1. 53 Gram weights
2. leave primary spring stock
3. change secondary spring position to 2-1
4. 175 main jet
5. drop needle one slot.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
