polaris 700
Old Oct 24, 2006 | 07:06 PM
wyant007's Avatar
Default polaris 700
Hey, anybody know what i should do, my 2002 sportsman 700 keeps sucking water into the motor every time I hit a good size puddle. I went on a poker run and hit two puddles, the first was up to the racks and the second might have been deep as the tires. I can understand the first but not the second. I started watching other riders with polaris's and they hit the same drinks and sped off? It seems my problem is with my atv.
And anyone know what my cross reference for an air filter might be?
Old Oct 27, 2006 | 08:02 PM
TJ700's Avatar
Default polaris 700
in your motor or the clutch housing?
if its in the motor, id check the airbox seal.
#1 reason for water in the motor.
Old Oct 27, 2006 | 09:03 PM
BigDog800EFI's Avatar
Default polaris 700
Also check the foam under the tank cover. It should be around the air intake and the clutch intake.
Old Oct 27, 2006 | 09:26 PM
Ridemhard's Avatar
Default polaris 700
I had a real problem with my 05 700 getting water in the belt housing. It was in the dealership a couple of times. Turns out that on top of the belt housing where the other piece that goes up next to the gas tank was not sealed properly. Could be something to check.
Old Oct 28, 2006 | 12:25 PM
ktmmad's Avatar
Default polaris 700
Make shore your airbox plug is in when playing in water, and out when in deep snow.
Old Oct 28, 2006 | 12:31 PM
Default polaris 700
Good point. I have seen many atvs with that plug missing...
Old Oct 30, 2006 | 05:19 PM
wyant007's Avatar
Default polaris 700
Thanks fellas I will start checking these hints out. First thing, I am going to check is the foam around the tank cover. It has been wadded up since I purchased this used ATV. I have been just pushing it back into place just to get my seat back on.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
