predator suspension setup
do you have a standard predator or a TLD? if your going to race GNCC ironman, you may want to look into buying a set of front TLD shocks (Fox Podium X shocks with Piggyback Resiviors) mainly because you can fully adjust the compression rate on the internal piston, and you wont experience shock fade with having the resivior.
if you do decide to go and purchase those shocks, i reccomend buying a set of Works or comporable progressive rate dual or tripple rate springs. that will really make things nice.
