Trailblazer questions
Old Dec 19, 2006 | 08:02 PM
Fenton88's Avatar
Default Trailblazer questions
Trailblazer Top End Pipe
This new pipe is designed to produce hard hitting mid-range acceleration and great top end power.
8 HP increase over stock. Great for racing.
99-02 models PAT40000 $229
03-04 models PAT40003 $229
Spk. Arr. Sil. (99-02) PAT30044 $149
Spk. Arr. Sil. (03-04) PAT30071 $149
Lite Alum. Sil. (99-02) PAT30045 $99
Lite Alum. Sil. (03-04) PAT30072 $99
Steel Sinencer (03-04) PAT40005 $60
Clutch Kit Stock Cylinder ATC30052 $49
Clutch Kit Ported Cylinder ATC30058 $96
I am lookin at these. I think i want the 99-02 for 229 but what else do i need to buy? I have a K&N and 23inch mudlites which i would like to get rid of and go down to a 22" razor? any info would be great
Old Dec 20, 2006 | 12:04 AM
scrammersam's Avatar
you prolly want a silencer and get the clutch kit. dont forget to rejet. and for tires what kind of terrain are you riding?
Old Dec 20, 2006 | 08:08 AM
ftwflh's Avatar
If you go with this pie get a silencer with sparkarrestor and the ported clutch kit.And when it is time to do a top end get the cylinder ported then.
Old Dec 20, 2006 | 08:25 PM
Fenton88's Avatar
So I should get the Spark Arrestor silencer for 149? and the clutch kit for the ported cylinder? I can run that kit with a stock cylinder? will it still be effective? and for tires i ride gravel and dirt trails with a bit of mud nothin i need the mudlites for.
Old Dec 21, 2006 | 08:11 AM
ftwflh's Avatar
I think the only dif in the kits is the helix.If so just run the stock helix in it.But a ported kit will work on a stocker.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
