runing cooler
Old Dec 28, 2006 | 03:23 AM
cowboy49's Avatar
Default runing cooler
howdy yall i have a 2004.5 sportsman 700 and the fan is shot, since ive owned the thing ive noticed the fan kicks on often/alot, i use it for hunting primarily, but plowing in the winter, was wondering if theres a way to get it to run cooler, also i got really stuck last august and blew out both front cv joints and a belt, im assuming that the clutch needs to be balanced or adjusted. Im running 27" mudhogs and was wondering what a good cluch kit might be. And with the awd selector in the off position, and the tack screen saying its off, seems like theres always a front wheel pulling, like theres no tru 2wd is that normal???
Old Dec 28, 2006 | 09:59 AM
Kerbbirds's Avatar
Go to your parts store and get a can of water wetter, or a simalar product, half a can in the radiator makes quite a difference, make sure your radiator is clean. I put the 800 belt on my 700 seems to be stronger. Change the fluid in the front diff, use the polaris hub drive fluid and see if this helps.
Old Dec 28, 2006 | 10:31 AM
BigDog800EFI's Avatar
For a clutch kit I would recomend the HeelClicker. You don't mention anything about doing maintainance. Do as k-bird says and change fluids and also completely remove the radiator from the machine and give it a good cleaning. No matter how good of a job you thing you do on the radiator, it will not be completely clean until you take it out.
Old Dec 28, 2006 | 01:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your going to a product in the rad to help keep it cooler make sure its compat. w/ the antifreeze so it wont harm or it wont make it freeze up in real cold temps. there a product thats called radiator relief that you add w/ your antfreeze that wont harm nor change the freezing point. use anywhere between 4 to 8 onces w/ the 2 qt systems we have.
Old Dec 28, 2006 | 05:41 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Just another fact here the Rads usually plug from the rear or back where the fan is...Check that area and clean good...Taking it out is best.....caper.....
Old Dec 28, 2006 | 10:49 PM
cowboy49's Avatar
thanx guys as for the radiator being clean, you can see light through it, lmao, my wifes jealous of this toy. and for using an 800 belt what year or does it matter. and changing fluids i must have cycled 3 gallons through that front diff
Old Dec 28, 2006 | 11:18 PM
Seeing light through it and haveing it clean are not the same. It will be cloged in the corners and in the center where the the fan blade hub is. I would also not recommend the 800 belt. It may cause creeping or make it hard to shift gears. Stay with the recommended Polaris brand belt.
STLyamwar
Jul 25, 2020 04:44 AM
ronnierhino06
Nov 9, 2015 12:56 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
blessedn09
Aug 9, 2015 03:07 AM
metal249
Jul 24, 2015 01:00 PM
