venom winch ?????
Old Jan 8, 2007 | 10:41 PM
onesavage's Avatar
Default venom winch ?????
i will give that a try ,,,thanks for the help..should i check anything else when apart:[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 8, 2007 | 11:08 PM
v2rider's Avatar
No, thats about all you can do from that point, and you should be good to go[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 9, 2007 | 03:07 PM
onesavage's Avatar
so i pack the the end w/ the wires not the geartrain end..
Old Jan 9, 2007 | 03:39 PM
v2rider's Avatar
Yes, the end with the red and black lead coming off of it, it has two bolts i think holding it on.
Old Jan 9, 2007 | 04:19 PM
  #15
onesavage's Avatar
i plan on doing this tonight after i get out of work..when i take the cap off will pieces fall out??? and do i need to grease the geartrain... i have a sportsman so i may need to pull thewinch off or ft of the atv bumper to reach>>>take the cap off and pack the grease in/re-assemble and run it to see if it quites down
Old Jan 9, 2007 | 04:28 PM
  #16
v2rider's Avatar
I reccomend taking the winch off the ATV, so you can place the winch with the cap in the upward position. I think there is a spring, or something, i cant remember, but take the cap off slowly, and you will get a good look at it.
Old Jan 9, 2007 | 04:40 PM
  #17
onesavage's Avatar
thats what t thought you would say....i post my findings in a little while
Old Jan 9, 2007 | 09:50 PM
  #18
jefffoxsr's Avatar
I have a venom winch. It is on the rhino. It has worked well so far.
onesavage.
any info you can post after you grease it would be appreciated.
Old Jan 10, 2007 | 10:21 AM
  #19
onesavage's Avatar
completely disassembled the slow/loud warn motorand geartrain every piece was taken apart and cleaned you would not believe the amount of dirt and krud in it....cleaned and re-lubed with high temp wheel bearing grease(recomended by warn) and this thing may just be better than new (quiter for a fact) dont know about the pulling power but it sounds alot better..i will do this more often... real easy and when you see all of the shi** inside you will agree this is one more thing to add to the maintance list .lol.. just do it you will be amazed at the difference.. took a hr and a 1/2 from the quad to back on
Old Jan 17, 2007 | 11:25 AM
  #20
clint6760's Avatar
I just bought a venom winch and haven't installed it yet. Where exactly do you put the grease at? Right once you take the cap off, do you pack grease around that cylinder or do you have to take the whole end of the winch off up to where the cable and stuff is in the middle of the winch. I was just making sure before I put the winch on the 4-wheeler. THanks
