venom winch ?????
Old Jan 7, 2007 | 09:30 PM
onesavage's Avatar
Default venom winch ?????
time to buy a new winch ,,or rebuild the warn2500# a second time... i new i should have bought a 3000#.. well iguess the Q is has any one tried a venom e-bay 89.00 w/ a remote lead,, and the specs are very close to a warn .. just dont want to have junk w/ i realy need it ,but in the same note my warn left me stuck and pretty ticked off.... any help or comments would be great i like to be a informed consumer
Old Jan 7, 2007 | 09:57 PM
06LimitedPred's Avatar
read the other topics about them. They're junk IMHO, i bought one and only test used it once, then after having it for a couple of months, went to use it and it's locked up solid.
Old Jan 8, 2007 | 12:46 PM
Nogotie's Avatar
I have an extreme 2500 winch from ebay probably made by the same company Ive only used it a couple times once to plow snow the other to pull out a Polaris 800 sp ( No Im not trying to rip on Polaris ! ) and it worked just fine But some ppl say it has slow line speed Its my first winch so I wouldnt have anything to compare it to>>
Old Jan 8, 2007 | 08:22 PM
v2rider's Avatar
They will freeze up if you dont change the grease in them to a good quality grease. The Venom winc is as good as any other, when the grease is changed. They come with a cheap grease that drys up after a couple months and the winch freezes up. Ive had mine for a while now, and it has outlasted my buddies warn winch. Just some good quality synthetic grease. I personally use Amsoil for everything
Old Jan 8, 2007 | 09:14 PM
Skilz's Avatar
Ditto ,,,,On the grease ,,I bought an Extreme 2500 and also used it a few times then it slowed down a bit ..No problem opened it right up Synthetic grease went in ...And BAM just as good and fast as the Warn 2500 i have on my other machine ...( Cheap And Good ) ....
Old Jan 8, 2007 | 09:25 PM
onesavage's Avatar
i had the dealer do my winch rebuild last time(they replaced the motor and it dont say warn),but anyway now its getting slow and loud ...is this a grease issue??? is it easy to diag a problem like this.i cant say i have not put a beating on it//just loud and weak now......
Old Jan 8, 2007 | 09:28 PM
v2rider's Avatar
Putting a good quality synthetic grease into it cant hurt, and can only help. And its VERY easy and cheap to do, so i would do it before running it anymore
Old Jan 8, 2007 | 09:36 PM
onesavage's Avatar
and how would i go about doing that,,i guess i didnt know i had to .... do you just open a drain plug????
Old Jan 8, 2007 | 09:37 PM
onesavage's Avatar
i have had this up to the gas cap a few times in the river
Old Jan 8, 2007 | 09:59 PM
v2rider's Avatar
You have to take the cap off by taking out the bolts. The cap is the end with the wires coming from it. Then pack grease around the cylinder inside, and replace cap. Run the winch for a few seconds in and out. It will sound weird for a few seconds, but thats the grease wearing off the contacts, and its normal. Your good to go after that!!
