Oil in sportsman 500
in the book it just says used oil API CERTIFIED SH. That is if i do not want to use the polaris oil.
the mobil 1 exceeds the sh rating
some say to use regular 10-30 oil for a few hundred miles after the break in oil, to help seat the rings, prior to putting in the slick stuff
.02c
Mark
It's freekoun cold up here
.02c
Mark
ive had extremely bad luck with amsoil... i have done deep research on amsoil and come to the conclusion that it is not better then mobil oil or the polaris stuff... in my case it is worse... i have had two 2-stroke engines fail using the 2-stroke amsoil and have had 1 four stroke engine with bearings gone out using amsoil, couindence... i think NOT
in my opinion the stuff is cheap and over priced all you pay for is the "name"
