Antifreeze check
Old Jan 24, 2007 | 07:43 PM
miniexcavator's Avatar
Default Antifreeze check
I just tried to check my antifreeze strength but after I took the cover off the overflow resevour I could'nt get the hose in from the tester, there was a rubber stopper in the way or something. How do you test?
Old Jan 24, 2007 | 07:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just take out the stopper. pry it out and then replace after testing.
Old Jan 24, 2007 | 07:55 PM
right now the panels are so cold that I'm afaid to try to remove them so I can get at it,but thanks I thought My cap may have come apart 2004.5 500
Old Jan 24, 2007 | 08:19 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Does the Factory set the freeze-point for the rad....Or is it the dealers due to the different locations all these quads are sent(U.S. and CAN.) EX. warmer and colder climates....Thanks...Caper.......
Old Jan 24, 2007 | 08:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as far as i know they are factory set since the dealers dont fill them. i ment to pry off the insert up thats under the cap. it should be good for at least -30 below f. a 60/40 mix is good for that i think since a 50/50 is good for -40
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
