1999 sportsman wiil not engage AWD in reverse
Old Jan 23, 2007 | 10:35 PM
LittleBuddy's Avatar
Default 1999 sportsman wiil not engage AWD in reverse
Can anyone give me some ideas please. I am unable to get into 4 wheel drive when backing. I have bypassed the override switch but to call me a rookie at this would be polite. The AWD is working fine in forward gears.
Thanks for thinking
jay
Old Jan 23, 2007 | 10:43 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
You can't just bi-pass the over-ride switch.....This is NEEDED for AWD in reverse...........There are kits that you can get to STILL have AWD in reverse but the engine is not limited.........do a search here to find more info..I don't have this done....Lots others do....Mostly for plowing..........Thanks...Caper.......
That over-ride buttom needs to be pushed for AWD in Rev. Normaly....Factory get my drift!!!!
Old Jan 23, 2007 | 10:53 PM
Sorry what I meant is that I put a kit on to not have to use the button in reverse for plowing purposes
Old Jan 23, 2007 | 11:17 PM
Did you do the Mod yourself............If so.......Put it back just to see if your AWD will work in REV. then go from there...........Did it just stop doing this now ...or never did work after trying to hook up the bi-pass....Caper.......
Old Jan 23, 2007 | 11:25 PM
Groogs's Avatar
Was it one from quatovator.com? I am looking at hooking one up to mine. I did some looking back on people talking about them in these forums and have heard nothing but good things about them.
Old Jan 23, 2007 | 11:28 PM
I did not do this rev. override to mine.........I don't plow with them..........Someone else can help you there.........They do seem to work fine though...As per what I read..............caper........Did you try a search...........??????
Old Jan 23, 2007 | 11:30 PM
Yes I did the mod myself and it was not working prior. I thought perhaps the switch was bad and by putting on the mod it would bypass the switch. yes it was from quadavotor
Old Jan 24, 2007 | 08:27 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did the overide button work b4 just t to back up, but not in awd? sounds like there is a wiring issue or maybe the gear slector switch. not sure
Old Jan 25, 2007 | 08:51 AM
I belive that it did because I was able to back fast with no mis firing
ScopeZ_
Jul 28, 2015 01:44 AM
kdg723
Jul 25, 2015 01:20 PM
Schneider
Jul 24, 2015 05:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 10, 2015 12:42 AM
