Checking "crankcase" oil in 02' scrambler 90 ?
Old Feb 6, 2007 | 09:17 PM
SherpaT350's Avatar
Default Checking "crankcase" oil in 02' scrambler 90 ?
In the owners manual it says to unscrew the plug on the top of the case and look at the dipstick . Well, when I unscrewed the one on my daughter's , it is just a plug. Did the dipstick part fall off somehow or is there another way to check the oil level ?
Also, what do you use for oil in these little engines ? Genuine polaris synthetic trans oil or another brand ? When I drained the oil out, it looks purple . Is polaris oil purple ?
Thanks,
D.
Old Feb 7, 2007 | 12:10 AM
BigBlueScrammy's Avatar
What manual are you lookin at? The Scrambler 90 is a 2 stroke. It does not have a crankcase with oil. It mixes oil with the fuel that is burned. It does have a little transmission gear case that holds a little oil. It should have a small 2 stroke oil resivoir under the seat as well, if it hasn't been removed.
Old Feb 7, 2007 | 12:15 AM
SherpaT350's Avatar
I am meaning the gearcase , wrong terminology .
Sorry,
D.
Old Feb 7, 2007 | 12:18 AM
Here is the link to the Parts land diagram. I forgot that the crankcase and transmission are housed in the same structure. They do not share oil, it is seperate cavities. However they do refer to the whole unit as a crankcase. Part # 9 in the diagram is the checkplug. It does not show a dipstick so I'm not sure they have one.
Old Apr 12, 2020 | 09:37 PM
Notacrat's Avatar
Default Some people say something bc they Gota say something even if it's wrong/lame
Lame you should know what your talking about before talking
scram5050
Aug 30, 2024 01:39 PM
DeFox500
Jul 26, 2015 06:32 PM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
