The Polaris AWD Hub/Diff Thread
Old Apr 18, 2009 | 03:51 PM
  #31
helmethair78's Avatar
Thumbs up
Originally Posted by helmethair78
JD Parts
Roller Kit-MIA10666
Cage Kit-MIA10667
seal Kit-MIA10654
I just ordered these, I will be picking them up tomarrow and hope fully get it fixed this weekend....
The A-plate is MIA10656 I did not order this one.
Update:
I picked up my parts this morning. I got them installed and it works perfect. This is the way to go, much cheeper than Polaris prices....
Old May 31, 2009 | 10:42 AM
  #32
egautier's Avatar
Post 1997 Polaris Sportman 500 No AWD
The all wheel drive will not turn on my '97 sportsman. The switch it self seems to work but I can read any voltage at the switch and the LED does not turn on.
The problem started when I replaced the battery.
Do you have any suggestions?
Old Jul 25, 2009 | 07:02 PM
  #33
mikesec's Avatar
i have a question, how much does a hub cost and where can i get one cheap
Old Jul 25, 2009 | 07:11 PM
  #34
TLC's Avatar
TLC
My cousin bought the whole left strut including,spring and hub assembly on Ebay for $60 and it worked great.
Old Jul 29, 2009 | 01:16 PM
  #35
c6matt's Avatar
Does anyone have a wiring diagram for the 4WD system (96 Magnum 425) Does this system tie into the speedo? (I dont see any wires going to the speedo aside from illumination) If I run 12Vdc from the battery to the hub wires sshould the system engage? Thanks!
Old Jul 29, 2009 | 09:05 PM
  #36
TLC's Avatar
TLC
The speedo had nothing to do with the operation of the AWD until 2000.
Old Jul 30, 2009 | 06:55 AM
  #37
c6matt's Avatar
So the only input is the red button to ign power so if there is power at the switch there should be power at the hubs at any speed/shifter position?
Thanks for the help so far.
Old Jul 30, 2009 | 08:42 AM
  #38
TLC's Avatar
TLC
The AWD indicator bulb has to work ,its part of the AWD curcuit. Does that light come on?
Old Jul 30, 2009 | 09:02 AM
  #39
c6matt's Avatar
No, the light doesn't come on, so if the bulb is burned out it wont send power to the hubs?
Old Jul 30, 2009 | 09:19 AM
  #40
TLC's Avatar
TLC
Not from the wirring diagram I have on a 96 SP500 and from "No AWD post" I have read.
Use the "ADVANCE" search option on this site, use term "No AWD" +search "Title only" + catagory "Polaris".
You have alot of reading but you will find your problem.
