800 Fan - Overheating
Old Feb 27, 2007 | 10:31 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default 800 Fan - Overheating
Originally posted by: SickSixtyRider
There is some kind of regulator behind the radiator, down in front of the steering column that burned out on a buddy mine's 700 Sportsman. He has the same problem with the fan not turning on. We called the dealer and they said that would cause it not to work. I don't know. Check and see if yours has the same part burned out.
I am at that stage right now!!!!!! Waiting for mine to come in!!!!!...
When they go.....they can do different things....Mine would shut the quad off when my headlights are turned on!!!.....Caper................Part # 4011110 on the 2006 SP 450.......
Old Feb 27, 2007 | 10:32 PM
What year was your buddies 700 sportsman???.....Caper......
Old Feb 27, 2007 | 10:36 PM
SickSixtyRider's Avatar
04 I believe
Old Feb 27, 2007 | 10:58 PM
JasBeirne's Avatar
I'll check that SickSixty...thanks for the thread.
Only 8 bolts holding the front end on? That ain't so bad...seems like the more advanced these things get, the more things there is to go wrong...but man I like it when it works!
Thanks everyone.
Old Mar 1, 2007 | 11:19 PM
  #15
Mu2Doug's Avatar
My MV7 700 HOT light came on when new. Dealer thought surepower box (ECM) was bad and replaced it. This box fixed for about 1 month then atv would not shut off and HOT light came back on. This time, they installed a resistor somewhere in the harness and problem has not returned. Surepower box controls three things. It is a voltage regulator/engine temperature controller/solid state circuit breaker. Was installed under headlight. Also call dealer as there was a recall on 2004 surepower boxes. Good luck
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
