Anyone installed 12V outlet on Hawkeye?
i just did tonight on my sons it kinda easy i put it on the left side just above the dry box lid.
take your gas cap off and then the center panel where your gas tank is at .
do this to get a beter look just up under your handle bars.
i took a 1 inch hole saw and drilled right in the side then i trimed as needed with a dermal tool
be carefull when drilling not to go to deep just tought the plastic.
I have my winch contactor in the right side box already, so I suppose I could put the outlet there. Rickey, did you put in an inline fuse?
Which way did you put it in? any clearance issues?
jrooker6
Apr 23, 2016 07:36 PM
