01 scrambler dies
Old Dec 18, 2000 | 09:53 PM
ridefree's Avatar
My 2001 Scrambler 500 2x4 dies when you get off the throttle. It acts like it is flooded. Very aggravating and dangerous when going down hills.
Also the other day was riding through some brush when a stick hit the throttle control wire knocking it loose, when it was unplugged the throttle stuck in the position it was when unplugged about half wide open, NOT FUN. when we plugged it back in it worked fine. But got into a barbed wire fence before shutting the thing off, OUCH. Any ideas about the flooding??
Old Dec 19, 2000 | 02:06 AM
4wheelindakota's Avatar
actually it could be the exact opposite.
rather than flooding, it could be that your throttle cable has too much slack in it causing a gas shortage. on my sportsman last summer, the throttle cable was too tight and i loosened it. now that it's cold out, i had to take some of the slack out to keep it running at idle. the adjustment should be about 2 inches down the throttle cable from the handlebar throttle housing. pull back the rubber boot and unscrew it just a hair.
Old Dec 19, 2000 | 07:12 PM
Jeremy H.'s Avatar
definatley sounds like your throttle cable needs to be adjusted. I owned a 1999 500 4x4 and mine did the same thing when I first rode it. The cable will stretch a little, so it will need adjustment.
Jeremy
2000 scram 400 2x4, HPD pipe, clutch, silencer.
Old Dec 20, 2000 | 12:54 AM
spyder30's Avatar
Jeremy why did you get rid of your 99 Scram 500 4x4?
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Pissed off
Sep 21, 2015 02:33 PM
1000gade
Sep 9, 2015 03:35 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
