ATTENTION SPORTSMAN TWIN OWNERS....
My buddies 02 700 had a coolant leak that he couldn't find and sure enough I read this post, went and looked at his machine, and there it was. The leak just as described above. Thanks
It was cut/worn right though the plastic protector and the coolant hose. 2500 miles
#16
Both my 800"s where wore through the protective cover....A big thank you for posting this......I had a gates radiator hose in my shop and I cut a 6" peice(2 of them) and split them down the middle and put over my hose's and tie strapped them in place....easy fix..Thanks a bunch man...
#17
:..We just brought in all of our twins and checked the hoses..Most were worn or almost rubbed through..We have used a lot of different fixes..the best seems to wrap a larger hose around the stock hose and split a small hose and put on the sharp edges of frame extension...one of our riders re-routed the hose (not sure how Yet)..I have contacted Polaris and amsure they will come up with a fix asap...Tell all of your friends who own twins to check this...
#19
[img]i/expressions/face-icon-small-cool.gif[/img]Yes any thing to keep the hose from rubbing the frame..(this section is U shaped with the hose against it)..One of my friends put and old riding glove around it..Seriously any thing to get rid of the sharp edges..
