slip-on pipe for scrambler 500
Clutch kit it is! I know I said only one more question but... How easy is it to install clutch kit? I can follow good directions and I am somewhat mechanical, but I've never worked on anything like this. I called a local Polaris dealer and they didn't sound interested in installing an aftermarket clutch kit either.
You can get what you are looking for with out spending a ton on a clutch kit.Go with a White Bros. muffler.Get a Dalton black/white primary spring and either an Aaen blue secondary or HPD violet secondary spring.You wont need all the parts that come in some "clutch kits".As for the head pipe the stocker flows decent and with just a slip on you shouldnt need to rejet.
exmotocrosser
09-13-2019 06:12 AM
mrtidy
02-03-2016 05:00 PM
greg86hd
09-16-2015 12:32 AM
