Sqeeking brakes. HELP!!!!!
Old May 11, 2007 | 01:10 PM
grover521's Avatar
Default Sqeeking brakes. HELP!!!!!
Anyone run into a problem with squeeking brakes? My front right brake is sqeaking like a "sum-batch" and the only way to stop it is to get them wet. But, once they dry, it starts back up. Is there any way to adjust them or fix the problem. Any suggestions would be GREATLY appreciated.
Thanks in advance!
By the way, it's and '05 800 EFI...
Old May 11, 2007 | 01:12 PM
brutus450's Avatar
did you try putting "brake pad grease" on the calipers where the backs of the pads meet the caliper piston? like on a car?
Old May 11, 2007 | 01:30 PM
diesel10's Avatar
Did you back off the allen bolt on the back of the caliper? From what I understand you are supposed to back it off a half turn after you have pad to rotor contact. Second I had the same problem (brake drag when dry but none when wet) and I had some very hard clay mud stuck between the pad and the caliper. I removed the pads, cleaned better and the squeeling went away.
Old May 11, 2007 | 01:47 PM
grover521's Avatar
Yeah, I sprayed some stop squeep crap on there but it didn't help a bit. I really haven't taken the time to look at it closely but I will try backing it off of the disk to see if that helps. Thanks guys!!!
mattcraig1
Aug 26, 2015 03:08 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
RdingManiac420
Jul 10, 2001 02:11 PM
markkh
May 1, 2000 09:45 PM
wolverine_4x4
Feb 25, 2000 02:32 PM
