New piston seems to make a sqeeke sound,,,,,,
I got my new piston in and everything put together and I got the engine broken in. Well after the first gallon of gas the piston seems to make a loud sqeeke sound when started and would be constant while running. I have it running a little rich for the brake in period so I cant figure out what it is. It has great power so I dont think its a ring problem or it would be getting less compression. So if you gotta an idea thanks.
Yes it would, and an airleak like that could fry your piston (again). To make sure thats where it is, spread some water aross the head gasket where you think it may be leaking and check for bubbles. This sucks, oh well, I have a 3 inch sidewall slice on the my 400's left front tire, so I'd have to tak the recon anyway.
Mojave250A
07-11-2015 10:38 AM
