98 Polaris Express bogs down when I throttle up
Old May 22, 2007 | 10:09 AM
rvanorman's Avatar
Default 98 Polaris Express bogs down when I throttle up
This thread is for anyone who is having problems with their Polaris Express when they throttle up and the engine bogs down. No power. The symtoms are that the engine will idle perfectly until you give it the gas. It's then that the enging has no power and bogs down and may even back fire. Mine back fired and blew the exhaust pipe right off of the cylinder head. Although it is held on with springs I simply snapped it back into place.
After a long time of trying to troubleshoot this thing I found out that the ETC (Electronic Throttle Control) was wet. The ATV had been sitting outside for a couple weeks this spring and moisture had gotten into the ETC compartment. The ETC is a small 2" x 3" box found right above the throttle control. I opened it up with a phillips screw driver and found water in there. Enough water that there was a small pool in the bottom. So I went and got my wifes hair dryer and dried it out. Tried starting the ATV and Whalllla! I had full power again without the bogging down.
I am just writing this tid bit for anyone who has similiar problems with their ATV. Hope this helps someone. I know this forum has helped me in the past. Thanks.
Bob
Old May 22, 2007 | 11:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
so the condensation made the contacts messed up. good info to have.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
