bleed brakes
Old Jun 23, 2007 | 03:09 AM
shapay's Avatar
Default bleed brakes
how long does it take to bleed rear brake? thank's
Old Jun 23, 2007 | 09:11 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
depends if your trying to bleed all the old fluid out or just trying to get the air out. unless you have run the mastercylinder dry or got a hole in the line or something there shouldnt be any air in the system. but bleed it until straight fluid comes out and no air bubbles come out. just a thought.
Old Jun 23, 2007 | 12:27 PM
elkbow's Avatar
what is the problem on your rear brake?
if you problem is it doesn't work anymore, on alot of the 1998 or so an newer machines, the cups inside the master cylinder have a tendancy to retract, especially in the cold of winter...
to fix it, put a heavy weight, like a brick on the rear foot pedal, overnight, then get up in the morning, take the weight off, pump it back up with your foot, should have your brakes back
Old Jun 23, 2007 | 02:04 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i tried that trick and it did bring back part of the brakes.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
