Sportsman 4x4 adjustment?
Old Jun 25, 2007 | 08:53 PM
Motohoppie's Avatar
Default Sportsman 4x4 adjustment?
I have a 2001 polaris sportsman 500 ho.
The hillard clutch on the left side does not engage. It is not the clutch, as it works in a differnt machine and a working clutch does not work in my machine. The front differential is also working as it should.
I have checked the wiring down to the "blue silcone" and all is well. I was reading Clymer repair manual and it says the outer magnet pole is adjustable.... I don't see how it is.
Can the magnet portion of this go bad? How do check it? Other thoughts?
Help
Old Jun 26, 2007 | 07:24 PM
Motohoppie's Avatar
I fixed the 4x4 drive. I just tapped the sleeve seal inward with a rubber mallet and got the gap between the inner and outter poles into specs. It works perfect now.
Jmuddin284
Jan 19, 2026 07:16 AM
metal249
Jul 28, 2015 09:35 AM
kdg723
Jul 25, 2015 01:20 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
