sptsmn 90 won't start
Old Jun 30, 2007 | 04:17 PM
3711's Avatar
Default sptsmn 90 won't start
my 04 sprtsmn 90 will not start. it really wants but just wont turn over. i cleaned everything i possibly could changed plug but still no start
can anyone help me
Old Jun 30, 2007 | 10:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it firing, and getting gas? did you do a compression check?
Old Jul 1, 2007 | 08:58 AM
3711's Avatar
thanks
it is getting fire and gas
didn't think to check compresssion. it was starting fine then the next day didn't want to start changed plug it fired right up. then next start nothing but wet plug.
Old Jul 1, 2007 | 09:45 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Did you check the spark plug gap?
It sounds like it too rich ,did you play with or adjust any of the screws on the carb, Sounds like a carb problem.......As long as your spark is strong and not too weak!!!......................Caper,........
Old Jul 1, 2007 | 06:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your plug is fouling it must be getting too much gas maybe from the float level off or having dirt in there. when its running it runs good? when you start it up and run it for awhile check the plug to see if its black and fouled looking.
Old Jul 1, 2007 | 07:54 PM
Bastosako's Avatar
they dont have a tps like bigger sportsmen do they?
Old Jul 1, 2007 | 09:53 PM
Phoenix200's Avatar
did you try drainging the gas. I had to do that to one of the pred. 90s before we sold it. it was trying to turn over and was getting gas, it just would turn over. pulled the fuel line going to the carb, the gas shutoff and reserve, reconnected, fueled, and walah it started.
Jim
Old Jul 3, 2007 | 10:51 PM
HondaFinn's Avatar
I have a 2002 Scrambler 90 for the boys. I bought it from a friend who hadn't run it for years. It did exactly the same thing. The starter turned over but it wouldn't fire. If it has not been run in awhile the gas in the carb evaporates but the oil is left to raise "all kinds of fun" with the carb.
This is what I did to get mine going.
1) buy 3 sets of plugs
2) drain the gas and put new gas with SeaFoam in it.
3) open the airbox and look at the filter. The filter needed to be cleaned .
4) disconnect where the airbox connects to the carb
5) Spray carb with carb cleaner 3-4 times
6) Put a new plug in & put some gas down the cylinder. I blocked the rear end up so once it fired, I ran it for at least 15 minutes. I had to the the gas down the cylinder trick 3-4 times before it took off. I then took that plug out and put another new one in.
7) ran the next 5 tanks of gas with Seafoam in them
This may be overkill but it has run flawless since. There is nothing worse than having a sad child sitting on his machine that won't run
I hope this helps
HondaFinn
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
