How hard is it to change ball joint..?
Old Jul 3, 2007 | 03:38 PM
hc's Avatar
hc
Default How hard is it to change ball joint..?
I need to change out both ball joints on a 99 Sportsman 500. Don't have the tool to change them. Can it be done with out the tool?
Old Jul 14, 2007 | 03:43 PM
papacarson's Avatar
i did one on my 2005 700 sportsman,you need to come up with some sort of puller,i used a big socket and washers,and the old nut on thr ball joint,i found the secert was to heat the ball joint housing ,carefully not to melt rubber boot,keep tension on the joint by tightening nut,used a small torch to keep heating around the old ball joint,need to heat it pretty good,keep tightening the nut along with heating and it poped out.not to hard.put the new ball joint in freezer,that will shrink the nrw ball joint a little,when you are ready to put new one in,start heating the housing to expand opening,remove new ball joint from freezer and quickly push it in heated housing, one side slid right in ,the other side had to tap it with mallet but went in without to much trouble,and wham all done,hope this helps ,let me know how it worked for you
Divergent12
Dec 30, 2017 08:33 PM
Jazperman
Aug 7, 2016 08:12 PM
toonces
Dec 15, 2015 03:59 AM
musselmark
Jul 17, 2015 02:40 PM
toonces
Jul 11, 2015 12:01 PM
