polaris trailboss
Old Jul 5, 2007 | 04:30 PM
cchucky51's Avatar
Default polaris trailboss
an one have an exhuast pipe foe a 93 trailboss 250 if so would you like to sell?
mine is woren out i tried to weld it an it made it worst it melted an left a hole in it
thanks for any help
Old Jul 5, 2007 | 04:33 PM
scootergptx's Avatar
Supersock
Hired Gun!
Check ebay, they seem to always have one that is being parted out.
Old Jul 5, 2007 | 05:34 PM
cchucky51's Avatar
tried they have nothing?
Old Jul 5, 2007 | 10:43 PM
Scott267839's Avatar
did you check for different years? I know that they have used several parts for 2 or more years. I beleive you might have just missed one that was on ebay. I know there was one last week. Just keep checking.
I just bought a 93 trailboss 2X4 2 weeks ago and the throttle saftey switch was disconnected. I figured out that I had to push in and hold the overide switch to get reverse to work. Do you know what might be the problem?
Old Jul 6, 2007 | 07:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
explain in detail what its doing when you try to put it in reverse.
Old Jul 7, 2007 | 12:55 AM
Stendori When put and Rev. and push throttle the engine would just 'bog' down. (remember that the throttle saftey switch is disconnected and when the overide botton is pushed in it works). Today I had some time to 'play' with it. I found the battery only had 5 volts max. (I have be pull starting) I put in a old ATV battery that had 12 volts. It would still not start but would try. But now Rev works and it seem that the throttle safty switch is working also now. The head and Tail lights still do not work but that could be blubs. Would a low/bad battery make the saftey switch not work?
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
binky79
Jul 30, 2015 06:37 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
