2003 Sportsman 700 no speedo
Old Jul 9, 2007 | 03:56 PM
AllPolaris's Avatar
Default 2003 Sportsman 700 no speedo
Just picked up a nice 700 with 109 hours on the display, hours are working fine, but the speedo needle does not move and the odometer is not working.
Did the routine stuff, cleaned the speed sensor and unplugged/plugged the sensor back in to the speedo unit - no luck.
4wd drive does work,
Bad speedo, or sensor?
Thanks,
Old Jul 9, 2007 | 04:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its a toss up but would lean toward the sensor as alot of times the awd doesnt work either but i have read where the speedo was gone but the awd did work. wonder if theres a way to test that sensor? maybe saomeone w/ a service manual could tell ya assuming there all about the same in the bikes.
Old Jul 19, 2007 | 01:26 PM
otmctimmy's Avatar
Did you get anywhere with your speedo problem? I'm having the same issue with my 03 700. Local dealer told me it was the speedohead, so I found a used one, but same problem - no speed indicator, no odometer and my hour meter doesn't work although eveything else on the speed seems ok. If you come up with anything can you share it. Thanks
Old Jul 20, 2007 | 10:42 AM
jbbooks's Avatar
You probably have a bad sensor. If you unplug the sensor and use a jumper wire between the two terminals on the plug, you should be able to peg the needle all the way over. if it doesnt move, it probably isnt the sensor.
Old Jun 3, 2018 | 08:20 PM
Stinkeye's Avatar
Default Yooper 600 twin
thanks for the info my 600 twin has same prob ill update
Old Jun 4, 2018 | 01:11 AM
user493's Avatar
Moto Psycho
I hope you do. No one else has in 11 years. There's no telling if they got it fixed or not.
Jmuddin284
Jan 19, 2026 07:16 AM
velcro7279
Aug 24, 2015 01:15 PM
sweaver
11
Aug 18, 2015 03:47 PM
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
