Polaris 250 Crank seals
Old Jul 14, 2007 | 04:26 PM
bikepro's Avatar
Default Polaris 250 Crank seals
I just picked up an old Trail Boss 250 (88 to be exact), and It's sucking air through the pto side crank seal. I've heard that these can be done w/o splitting the case- I'd appreciate any advice I can get on this-specilty tools, tricks, etc. Thanks a ton!
Old Jul 12, 2008 | 11:50 PM
Pull drive clutch,use seal puller or screwdriver to pop up old seal,lube new seal with oil on rubber part,install,using a big socket if have one or BLUNT FLAT punch. Dont damage case or crank. Good luck. clutch puller tool needed
Old Jul 13, 2008 | 12:06 AM
Charlie's Avatar
If the pto side is bad likly the mag side is also bad. You will need to pull the flywheel and remove the stator. Both sides use the same seal. I drill a small hole in the metal part of the seal, screw a sheet metal screw in and grab the screw with vise grips then pry on the vise grips to pull the seal out. There is less chance of damaging the crank and case I think.
Old Oct 22, 2012 | 09:12 PM
88pjunkie's Avatar
Anybody know the number on the crankshaft seals
Old Oct 23, 2012 | 08:12 AM
TLC's Avatar
TLC
Wow this is my Favorite parts site and they show it, part#6 (pic) but they skip it on the parts number list,thats odd. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 23, 2012 | 08:51 AM
#3082162 stator side seal, #3084581 clutch side seal. OPT
Old Oct 23, 2012 | 11:02 AM
88pjunkie's Avatar
Old Oct 23, 2012 | 12:19 PM
Cycle Parts Warehouse and Cheap Cycle Parts have both seals. Just type in the two numbers I gave you down at the bottom and shows the prices. Just compare which one is cheaper on prices and shipping. Plus you might check a local dealer's stock as shipping may offset the cheaper online prices and may actually be better to purchase locally.These are the latest numbers from the original ones listed back in the 1980's. (3084581 and 3082162) BUT if you have a pre 1995 model 250(1985-1994) you can use BOTH #3082162 seals on both sides of the cases!(at least by the Polaris website listing) Confusing I know! OPT
Old Oct 23, 2012 | 09:14 PM
88pjunkie's Avatar
Default Seal for 250
Got the clutch side off and the seal rubber is completely gone. Chaecked 5 places today and no seals are avaliable. Goinf to check the bearing seal place in Chico in the morning. Let you know what happens.
Already tried to get the flywheel off. Has little tine cheah holes to use for the puller. Got one broke off already. Try to get it out tomorrow and will get 3 hard allen bolts and try again. Even used heat and a pop with a hammer amd nothing so far.
I saw where a fella had seals coming . Cant find where I saw the posting to find out from where he got them. Ugh its raining
Old Oct 24, 2012 | 08:02 AM
You're getting close! Make sure you're using metric bolts in the puller for the flywheel.Flywheel probably hasn't been off in years! This is a common engine made for many years and someone should have the seals. OPT
