polaris magnum 325
Old Jul 22, 2007 | 04:55 PM
cchucky51's Avatar
Default polaris magnum 325
any one have one of these this one is a 2001
having trouble when you put it in reverse an hit the gas is seems to bog down an seems to almost ready to stall?
any ideas what i need to do to fit?
Old Jul 23, 2007 | 02:16 PM
deanz400's Avatar
do you use your reverse override button ,yellow one left side
Old Jul 23, 2007 | 06:46 PM
duffus's Avatar
if you do use the switch.. maybe check the switch connection- it could be worn out.
Old Jul 25, 2007 | 05:39 PM
cchucky51's Avatar
it seems to work if you use the switch,
but on my trailboss i don't have to use the switch,
what is the switch actually for?
Old Jul 25, 2007 | 09:53 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cchucky51
what is the switch actually for?</end quote></div>
The button is a saftey feature to keep you from backing up too fast and loosing control.THe one on your old bike could have been unhooked.Too unhook it unplug the blk wire from the reverse limiter box.
Ramman1
Aug 11, 2022 01:53 PM
ronnierhino06
Nov 9, 2015 12:56 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
jettman
Jul 6, 2015 12:16 PM
