compression test
Old Aug 6, 2007 | 07:38 PM
KBOB5's Avatar
Default compression test
Can some one tell me how many psi the guage should read on my 05 sportsman 5oo when i do a compression test?
Old Aug 6, 2007 | 09:35 PM
theCATman's Avatar
4 stroke engines use a compression release upon starting, but it should be somewhere around 120-130ish
Old Aug 7, 2007 | 01:06 AM
KBOB5's Avatar
so what does it mean when the compression is between 75-100
Old Aug 7, 2007 | 09:47 AM
theCATman's Avatar
It sounds low, but like I said with a compression release it could be that low, doubtful though. Why are you compression testing a 2005 engine?? Did you do something that may have harmed it?? Call & ask the local Polaris dealer's head mechanic what it sould be reading. They have all that info on hand.
Old Aug 7, 2007 | 11:51 AM
03scrambler500's Avatar
I just looked at my sevice manual for my scrambler and it says that it should be somewhere between 70-90 psi but it verys on cranking speed. It sounds like your compression is just fine.
Old Aug 7, 2007 | 08:47 PM
dirtsnow's Avatar
because of the compression release they want u to do
a leak down test on the motor. what is wrong with your
motor that u are checking compression? are u doing it
just for reference?
Old Aug 10, 2007 | 10:48 PM
KBOB5's Avatar
my motor boggs evry time i take it out, but when i'm at home it runs fine,i think it's a jetting issue
Old Aug 10, 2007 | 10:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have you checked the clutches as they will make it bog some if there worn out or bad belt, or extremly dirty. just a thouhgt.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
