02 magnum 500 - Good buy?
Well I have had a 1999,2000,2001 and 2002 Magnum 500 ATVs. They all were great machines with very little problems. The strong 500 engine along with the straight shaft on there rear makes it one tough atv. However I never ran any of them to 2000 miles so I would check it out a bit.
How much do they want?? Do you know the owner? If it is anything over $1800-$2000 range I would walk. With some looking you should be able to find a 99-02 Polaris 400-500 atv in that $2500-$3000 range with a lot lower miles. I look at Craig's list everyday and they pop-up all the time.
Here in Minnesota craigslist... Magnum 500's, 01-02's, they're going for $3000-3500, miles 1500+/-. Seems a little high but our used market will get that. Not sure how the market is where your at though. I certainly wouldn't walk away from a 02 magnum if it's not under $1800-$2000?? Anything under $2800 I would think is a good deal, $2800-3000 a fair deal.
WENTY
WENTY
Frisky2050
04-09-2020 11:19 AM
Technical and How-To Articles
07-02-2015 01:34 AM
