98 sportsman drive belt ?
I have a feeling my drive belt is getting bad. Im not sure if its ever been changed or not. When I first get on it and take off, it drives sluggish for a little ways, and then picks up and runs like it should. As if it was catching another gear or something. I have never worked on one of these belts before, and a buddy of mine says the polaris belts are tuff to mess with. I dont know anyone that knows how to do it, and what I would like to know is if there are any instructions out there on the net that maybe some of you guys know of.
I would like to know kind of what im dealing with before I go tearing into it. Like special tools, or tricks to make it easier.
Thanks.
Thanks.
a sportsman belt is really easy to replace. once you take off the foot well and the bolts to the clutch cover and unbolt the vent pipe and pull the cover off. you'll be looking at the clutches. i would clean them out w/ compressed air in you can and maybe even see if there are worn out parts. any questions fell free to ask.
Took it down to the clutches like you said, and blew everything out. Lots of dust came out of the front one ( I assume "primary clutch"?). Everything looks nice and clean in there, and apparently doesnt leak. The belt looks loose enough that I think I could slip it over the rear "clutch" by turning it, and slipping it off alittle at a time. Should it be that loose, and is that the way to take it off?
The belt looks fine though, and doesnt have any cracks in it. Im not so sure that this belt might be glazed over, and maybe that is why it slips at first. anyway,, thanks for the help.
yes(if your talking about the prim.)you can push the sheeves together as the spring has not much for preload. no, you really shouldnt be able to roll off the belt that easy. its an ebs clucth it should be fairly tight and it should be setting a little above the secondary(back) when its at rest.
