wont run right at mid to full throttle
Old Sep 16, 2007 | 07:47 PM
  #21
02huntinquad's Avatar
Default wont run right at mid to full throttle
well i know now what i didnt know then, the cam is hooped, the exhaust lobe is almost totally wore down!!! what the hell causes this??? going to order one monday morning ($290), not too bad i guess. THANK YOU EVERYONE for your imput and suggestions, much appeciated. also would i be able to swap the cam with a different machine like a 500 HO to get more performance, since i have to change the cam anyway
Old Sep 16, 2007 | 08:07 PM
  #22
drlang's Avatar
Yep the 500 HO cam will go right in. Don't forget to get the cam follower also that will be worn too. Doc
Old Sep 17, 2007 | 12:43 AM
  #23
shouldn't the valve clearence adjustment take that little bit of wear out?? are the cams for all the polaris quads interchangable???
Sjrpp
Jun 2, 2019 07:25 AM
Ronk407NY
Feb 13, 2016 11:05 AM
Polarisman1123
Sep 13, 2015 10:06 AM
Anomers
Aug 16, 2015 11:06 AM
blpersinger
Jul 15, 2015 09:56 PM
