polaris scrambler 500
Old Sep 14, 2007 | 05:20 PM
americanbulldog's Avatar
Default polaris scrambler 500
i qaas thinking of getting a polaris scrambler 500.and i was wondering a few things,
like are they reliable?
whats the top speed?
is there performance upgrades that i can get but still keep it reliable.or stuff to make it more reliable.
thanks
Old Sep 14, 2007 | 06:36 PM
ftwflh's Avatar
Top speed isnt that great 60-65 mph and that is about all you are going to get even with mods due to the 4x4 gearing that is not a good thing to change.But with the right mods the 500 Scrambler can be quick and have more power than you can use.
Old Sep 14, 2007 | 06:41 PM
60-65 is good.at least for the trail riding ill most likly be doing.
also can the scrambler be used for plowing in the winter.and what you men more power then i can use.how could you gain power without speed.
Old Sep 14, 2007 | 06:56 PM
scramblerXrated's Avatar
i plow my drieway with my scrammy and it does great. i have plenty of mods done, all of them are easy. alot of your power to the ground power is gained thru proper clutching. in stock form they are clutched rather conservatively. a clutch kit can give you instant seat of the pants feel, and make your trail ride much more sporty.
theres plenty of mods available, and they wont effect your reliability.
X
Old Sep 14, 2007 | 06:57 PM
RickCJ7's Avatar
Adding power doesn't change your gearing! Redline is redline!
Muffler/airbox/clutching etc.. all add power but don't raise the redline.
Old Sep 14, 2007 | 07:00 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RickCJ7
Muffler/airbox/clutching etc.. all add power but don't raise the redline.</end quote></div>
It dont work like that with a Polaris 4x4 system.Change the gear ratio and it messes up the 4x4.You can get more rpms by clutching but the motor wont stand much over 6800.
Old Sep 14, 2007 | 07:09 PM
so i am a big guy.around 280-300 could i get power out of a scrammy to pull my weight up hills and in trails easy.
Old Sep 14, 2007 | 10:29 PM
ftwflh's Avatar
You wouldnt be disappointed.I tip the scales at 230 and mine does me great.
Old Sep 16, 2007 | 04:27 PM
JRodTHF's Avatar
I've been the original owner of a 2001 Scrambler 500 4X4. I put about 750+ miles (HARD miles at that) on the machine a year and other than this year, I've only done oil changes and general lubing (which is extremely important!)
I just took it in; had a tune up, rear pads and tie rod ends replaced. No biggy.
I also plow my corner lot with it. The machine is not built for this (because there is no gear like a Sportsman), but as long as you take it easy and don't burn up the belt, you'll be fine. I've done parking lots with it when my buddy couldn't use his truck for his business.
I ride with about 15 guys when I go up and honestly, everyone of them has a different machine (which I've test driven all). If I were going out to get another quad, I have no doubt it would be another Scrambler. It's a perfect machine.
And regarding your size. I'm 260lbs. I just tweaked my rear spring (easily done by twisting a nut) to increase the stiffness so the rear didn't sag to much. It has enough stock power for everything you'll need.
Old Sep 17, 2007 | 03:33 AM
thanks for all the replies.keep them coming.i have some other ?s.
if taken care of how long could one of these atvs last.
and what are some mods that are easy to do that gain power.
thanks
