Sp carb troubles
Old Oct 23, 2007 | 11:49 AM
edmo500's Avatar
Default Sp carb troubles
yeah I have ran the same jets in this carb since ive owned it for the last 4 years in the same area. I actually just put in a new pilot jet, the other one was breaking down and kept plugging. But I kept it the same size. I can take the airbox off and see that the CV slide is opening half way at full throttle.
Old Oct 23, 2007 | 11:57 AM
sjbr549's Avatar
you already done this probaly but have you blowed out the fuel lines could have something in it.i've never had one do like that.my slide doesn't go all the way up either. but it does run fine
Old Oct 23, 2007 | 11:58 AM
edmo500's Avatar
yeah I have replaced the fuel lines from the tank to the carb...
Old Oct 23, 2007 | 12:08 PM
sjbr549's Avatar
what's the model number for your quad should begin with a w
Old Oct 23, 2007 | 12:14 PM
  #15
edmo500's Avatar
I am not sure what it is, I am not near it now.
Old Oct 23, 2007 | 12:25 PM
  #16
sjbr549's Avatar
with the model # you can go to bikebandit.com and get blueprints for your model.it could help.is the air filter clean or the exhaust clogged up that'll make it run poorly
Old Oct 23, 2007 | 12:28 PM
  #17
edmo500's Avatar
okay I will have to look into that. I just replaced the air filter, and I dont think the exaust would be plugged. I took the muffler off a while ago and cleaned it out. If I hold the throttle in the mid range it will usually kick in and go, but thats about the only time....
Old Oct 23, 2007 | 12:36 PM
  #18
sjbr549's Avatar
could have a clutch issue
Old Oct 23, 2007 | 12:38 PM
  #19
edmo500's Avatar
no I dont think Its that, I have been thought clutches too. I wont rev out, even in neutral.
Old Oct 25, 2007 | 08:42 PM
  #20
Polaris500HO4x4's Avatar
Just wanted to ask you... when you installed your new cam... is the timing set exaclty?
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
