New 800 Dies on Corners, Pops and Studders in Reverse
The popping and stuttering in Reverse is probably because you've hit the rev limiter. Try holding the Reverse Override button and see if that helps.
As far as dying on corners, if you mean very sharp low speed corners when you have the handlebars cranked all the way to one side, then it could be that the key chain (if there is one) is catching on the gas cap and causing it to shut off. If not, check the throttle cable free-play for excessive slack.
There might be one other solution that can be found in the forums but try those things for now.
Report back to us on your results.
Njrider1230
07-29-2023 05:16 AM
gorylewis
27
10-04-2015 05:22 PM
house1
08-09-2015 10:49 PM
