The Sportsman ride
Old Nov 8, 2007 | 12:09 AM
NoJoke's Avatar
Default The Sportsman ride
Howdy everyone.....Off the showroom floor......which would have the best overall ride, the X2 500 or the Sportsman 500? Softness of ride, roll, stability....
Old Nov 8, 2007 | 12:20 AM
aht_six's Avatar
I tried to test this exact thing out out a couple weeks ago. My son rented a 500 X2 and I rented a 500, we switched machines numerous times. There was not a huge difference but I thought the X2 rode a little smoother and the 500 turned a little tighter. My son did scrape the bottom of the X2 crossing a deep irrigation ditch that I cleared with the 500 but he was riding 2 up at the time.
Old Nov 8, 2007 | 07:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would think w/ the x2 it would have a little stiffer rear spring set up for the extra rider there for would ride rougher over hard stuff. maybe they have progresive springs that get stiffer w/ more weight put on it.
Old Nov 8, 2007 | 12:22 PM
The X2 has a nice ride because of the longer wheelbase. It is like the difference between a short cab and a crew cab. It's more stable on hills because of the extra length but also does bottom on obstructions a little more than a regular Sportsman. I put some 3/8ths aluminum on my quad's footwells to fix up a spot where the plastic got gouged out by a tight squeeze in rocks. The front end on both quads is a little soft to me. The X2 does not squat as much as a Sportsman because the rear springs are heavier. If you do a lot of slow technical stuff over big obstacles go with the regular Sportsman. The X2 will scrape a little more, as said. For everything else, I personally think the X2 is better. More stable, less squat, better up and down hills, stiffer rear suspension, less front to back motion, etc. Just my two copper coins worth.
Old Nov 8, 2007 | 12:26 PM
sheepdogMSP8117's Avatar
I can't image a rear suspension stiffer than the single seat Sportsman. If the X2 springs are stiffer, I don't want anything to do with that....LOL!!!
Old Nov 8, 2007 | 12:32 PM
Maybe my weight (about 350) has something to do with it. But, the Sportsman's I've been on had a lot of squat at launch. The X2 squats but it handles bumps a little differently because of how they angled the rear suspension.
neilbedwell
Nov 10, 2018 11:02 AM
Mphillips
Jul 29, 2015 08:53 PM
TLC
Jun 21, 2015 10:02 AM
atv1972
Jun 18, 2015 09:31 PM
PolarisPower500
May 17, 2015 02:28 PM
