NEED YOUR HELP
Old Nov 10, 2007 | 01:19 PM
94harley's Avatar
Default NEED YOUR HELP
<div class="FTQUOTE"><begin quote>Originally posted by: Snowman1000
By Drain the crank you mean pull out the little ten mm. bolt in front of the starter? I did and a couple drops came out but that was it. Also I am game for rebuilding the carb but im going to need a little assistance. I have rebuilt carbs before but most have been the diaphram style on old sleds. It probally has been six almost seven years since the carb was rebuilt maybe even longer if they didnt do it at the shop were I got it fixed the first time.</end quote></div>
Yes thats the plug. Run a wire through the hole to make sure its clear. If you need some help with the carb just ask. It's not a big deal to do those type of carbs. We'll help you.
