winch trouble
Old Nov 10, 2007 | 10:12 PM
shorse's Avatar
Default winch trouble
today i had to move my little trailer back a few feet, i figured the quad's winch would work great for it...
i hook it up, begin to wind it in, it gets tight, the quad starts to move a little bit, but grabbs and then i hear a clicking and the winch just stopped...
is there an internal clutch that slips under too much pressure? i didnt think the trailer was anywhere near the 2500 # weight, but without tires it possibly could have been too much.... (it was just the chassis, i took the tires off to fix them both... )
did this do damage? It still wound back up under no pressure back onto the drum....
thanks,
erick
Old Nov 10, 2007 | 11:27 PM
shorse's Avatar
to combine threads and save bandwith....
In "Polaris Sportsman 500 HO" what does the H.O. stand for?
Old Nov 10, 2007 | 11:33 PM
SCRAMMYTODD's Avatar
Is the solenoid for the winch clicking when it gets a load on it?? Maybe check for a loose connection at the winch, solenoid and battery.
And the H.O.stands for High Output
Old Nov 11, 2007 | 09:21 AM
shorse's Avatar
so there should be no stopping, it should just move the quad and not just stop? it's only 4 days old, definitely warrantied...
thanks
Old Nov 11, 2007 | 09:24 AM
shorse's Avatar
just a thought....
i was driving through a stream... water up to floor boards... i pulled out and got it high centered on a log.. when i got off to winch, there was steam coming out from where the winch was... but i thought it was lower.... does this mean i fried it?
Old Nov 11, 2007 | 01:07 PM
The steam was probably water evaporating off the radiator/exhaust. If you were tring to pull a BIG trailer thats even near 2000# on ground with no wheels on it, you probably just snuffed out the winch. They may say 2500# but they probably won't pull that much.
Old Nov 11, 2007 | 04:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ive actually maxed out a 2000, and a 2500 lb winch by pulling until it stopped pulling and when i let off it actually reeled back out a little as the brake couldnt hold the weight and no harm has come to it. you may have a bad contacter(solnoide) where it just clicks. check connections first and tyo make sure no bear wire is touching and grounding it out.
Old Nov 11, 2007 | 06:56 PM
shorse's Avatar
i used it again to move a 8" round long that is roughly 15 feet long out of the stream. it did it without hesitation... go figure... maybe the trailer was just way too much for it.
Old Nov 11, 2007 | 07:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
even if it was too much weight i would still think you could have backed the cable out. as long as it still works but keep trying it often to make sure it doesnt mess up when you need it the most.
Old Nov 11, 2007 | 08:45 PM
shorse's Avatar
i was able to back the cable out and wind it back in once i disconnected it from the trailer.
