Stuck oil filter
Old Nov 28, 2007 | 06:00 PM
Thisoneguy's Avatar
Default Stuck oil filter
Yah good point silverado. I know in town here you can buy a kit with about 10 different sizes based on the number of flutes on the filter. Kind of a waste of money, at this point atleast. I'm gonna giver a whirl with the channel lock pliers, and a nylon ratcheting strap i found. If all else fails i'll buy the polaris end cap wrench thats designed for their filters.
Thanks for the advice all!!
JR
Old Nov 28, 2007 | 06:24 PM
ohnet's Avatar
Let us know how this turns out. I am a big fan of the pliars (channel lock style) like I said. When all else fails, I get out the big hoss pliars and never have a problem.
Old Nov 28, 2007 | 07:43 PM
1smokin50's Avatar
You can also buy the nylon strap, filter wrench @ any parts store. It won't break like the rubber one did... my .02..
Old Nov 28, 2007 | 08:07 PM
jleo's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: deanz400
I'd say a small pipe wrench ,heat it up aroud the base with a propane torch</end quote></div>
Im not sure if heating an oil filter which has oil inside is a good idea.
Old Nov 28, 2007 | 10:34 PM
  #15
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
I know this does not help now, I had similar prob doing my 1st change on my 800, after I got the filter off I bought a K@N filter, has a nut welded on the end of filter, easy on and off.
Old Nov 28, 2007 | 10:46 PM
  #16
trailbound's Avatar
Just a suggestion. On my 700 a few years back a small stone/rock was wedged in between the engine block and filter lip. Small rock, only about the size of a rice crispie, but as I tried to turn the filter off it wedged tighter and tighter and I could not get the filter off untill I found the rock and removed it. I turned it so hard before I found the rock that I pushed the rock right into the aluminum engine block. Just a suggestion for all.
Old Nov 29, 2007 | 09:58 AM
  #17
deanz400's Avatar
I've actually crushed a stuck on filter with a strap wrench but got it off eventually
Old Nov 29, 2007 | 12:19 PM
  #18
SpudRacer's Avatar
I wouldn't recommend a torch, but I would recommend a hot air gun to the base to warm up the metal and the old seal, that'll help it spin off a lot easier than a cold and stiff seal. That way you won't risk damaging your ride.
Tom
Bryson City, NC
Old Nov 29, 2007 | 12:24 PM
  #19
700 efi guy's Avatar
I have a pair of vice grips with a chain on them, they're good for grabbing round things, I use them lots to pull the oil filter off the car, but if you can fit a pair of giant chanel locks in there they'll work the best,
Old Dec 2, 2007 | 07:13 PM
  #20
flyinscrammy's Avatar
LOL!!! I just had this problem with my son's quad. I used the old Screwdriver trick. I lucked out, it mangled the hell out of it, but with a leather gloved hand holding the outside of the filter, oil leaking everywhere and that big a** screwdriver jammed through the filter, success within my reach!!!!!!
Let us know what worked to finally get it off. The hot air gun seems plausible.
Nosniborpapa
Sep 12, 2015 05:54 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
