Stuck oil filter
Old Nov 27, 2007 | 05:50 PM
Thisoneguy's Avatar
Default Stuck oil filter
Semi-anual lube and oil change on sp 700 was going great untill i encountered a very stuck oil filter. I have one of those rubber strap wrenches, and I literally broke the handle clean off. Just wondering if anyone has used the polaris oil filter wrench that the lady at the dealership tried to sell me. I'm feeling pretty sheepish for scoffing at the idea of buying a 30 dollar wrench to remove a filter. Is it just another strap type wrench, or a cap that fits over the end?
I also tried the old screwdriver through the filter and it simply chewed up the metal casing of the filter without budging it. Now i have a very greasy, serrated, mangled oil filter to remove. Not so fun as the weather has been dipping close to -30 C these last few days.
Any ideas for tips/tools, homeade or not would be greatly appreciated.
JR
Old Nov 27, 2007 | 06:26 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Is there a metal lip around the base of the filter?.............You can try to tap this very GENTLE with a flat screwdriver and hammer counter-clockwise to try and loosen right at the base!!!!..........Don't damage the surface face as the new filter will need to seal!!!!
I guess the person that put that filter on never did apply some oil directly to the gasket to lube it up first!!!...............Caper.................
APPLY oil to the rubber seal before installing new filter......This will make it ALOT easier to take off next time!!!!
Old Nov 27, 2007 | 06:31 PM
Thisoneguy's Avatar
Haha, well nothing like not following the instructions hey! It was most deffinatley the dealership who did the last change during a tune up. Not sure why they call it service when i spend this much time fixing their mistakes!
Old Nov 27, 2007 | 06:49 PM
ohnet's Avatar
I had a stuck oil filter on my lawn mower. I have a HUGE pair of pliars. I took out those and grabbed the oil filter (slightly crushing it) and it came off without much problem. If you can get a pair of those onto the filter, I'm sure it will come off. Of course it will depend on where your filter is. Good Luck.
OHNET
Old Nov 27, 2007 | 07:23 PM
jleo's Avatar
I used a 24" pipe wrench to get the oil filter off on my boat. Of course there wasnt anything in my way as im sure there is for you.
Old Nov 27, 2007 | 07:33 PM
xler8ion's Avatar
I think your best bet at this point is to go to NAPA or other auto parts store and buy an end type filter wrench. Take the new filter with you to get a good fitting one. It should work if the case is not compromised by the attempt with the screwdriver.
Old Nov 27, 2007 | 10:49 PM
SCRAMMYTODD's Avatar
I don't want to sound silly, but make sure you go the correct way. Lefty loosey, righty tighty [img]i/expressions/face-icon-small-smile.gif[/img] [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 27, 2007 | 11:14 PM
sheepdogMSP8117's Avatar
Advance Auto sells a part that fits over the end of the filter like a socket, then you just use a ratchet and 3/8" extension on it. It only costs a few bucks. You should be able to get a part like this from any auto parts store or even Walmart. Good luck.
Old Nov 28, 2007 | 03:13 PM
silverado 4x4's Avatar
One thing about those cap wrenches you put a rachet on. They don't always fit all brands of filters. I got one for mine & it wopuld only fit a fram filter no others. I no this really doesn't help but don't want you to buy the rong thing. Try a channel lock at the base that someone else already said it works on mine.
Old Nov 28, 2007 | 04:56 PM
deanz400's Avatar
I'd say a small pipe wrench ,heat it up aroud the base with a propane torch
