Hawkeye Clutch Rollers
Old Nov 27, 2007 | 11:06 PM
FNR's Avatar
FNR
Default Hawkeye Clutch Rollers
Hello,
Has anyone tried the 10 gram rollers as of yet? I have 25" mudlites on mine and was wondering if I should order the 10gram rollers or just remove the 2 14gram ones.
Thanks, Frank
Old Nov 28, 2007 | 09:55 PM
Rickeyparker's Avatar
Either one will give you about the same performance, it really works good with 2 removed but really im thinking having all 8 rollers in there will be better, Ive doen the 6 14 gram rollers and it really works good with the 25 inch tires.
Old Nov 28, 2007 | 11:11 PM
FNR's Avatar
FNR
Which jet did you use from the Dynojet kit>
Old Nov 28, 2007 | 11:19 PM
i used the 140
Old Nov 29, 2007 | 09:18 AM
TennesseeTider's Avatar
I have 8 of the red 12g rollers in mine and I like it with my 25" mudlites.
Old Nov 29, 2007 | 12:56 PM
FNR's Avatar
FNR
Hello,
Do you think the 10 gram rollers might not work properly?
Old Nov 30, 2007 | 11:53 AM
They will work fine, you will just lose some more top end.
Old Dec 2, 2007 | 07:39 PM
FNR's Avatar
FNR
Hello,
I put in the 10gram rollers, a jet kit and a KN filter. Took it out and it runs smooth and goes like stink compared to stock even with the 25" mudlites.
Old Dec 3, 2007 | 01:15 AM
what kind of top speed did you get it up too, the problem i had was that when climbing steep hills the front end got real light.
Old Dec 3, 2007 | 12:37 PM
FNR's Avatar
FNR
Hello,
Too much snow to test top end as of yet. I will let you know.
