warming up the oil in a 06 500 EFI
What is a magnet heater?
An engine heater is NOT needed, but definitely would benefit the engine. Cold starts are a main cause of engine wear, and warm oil will help out for sure. I fly single engine airplanes, and pre-heating the engine in the winter is standard practice.
I run my Sportsmans through the winter, and the temp gets below zero a lot. Neither one has refused to fire on the first turn of the key or stay running after that.
As long as it's a heater it will help. My Father is a heavy equipment mechanic and we went on a service call into the middle of nowhere for a skidder that wouldn't start. When we got there he asked me to go into the bush and find some wood. I thought he wanted a shelter from the wind, but he made a fire under the oil pan to warm the oil and it started in an hour or so.
Yowza... I'd never build a fire under an engine. His theory is right (heat the oil) but those big engines so often have various leaks and skims of fuel, oil, etc. on them that I'd be afraid of starting a very serious fire.
Glad it worked that time with no injuries.
