Scrambler Rearend Problems
Old Dec 10, 2007 | 06:24 PM
scramblerXrated's Avatar
Default Scrambler Rearend Problems
yes they are the same,,,
X
Old Dec 10, 2007 | 07:22 PM
tbsleeper's Avatar
make sure you do them right the first time...I've done mine three times and the third time i needed a new axle and carrier from the broken bearing ruining the axle and carrier.
Old Dec 10, 2007 | 07:51 PM
cdrmotorsports's Avatar
Alright. Thanks guys!
Old Dec 11, 2007 | 01:46 AM
Indslpwr04's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: tbsleeper
make sure you do them right the first time...I've done mine three times and the third time i needed a new axle and carrier from the broken bearing ruining the axle and carrier.</end quote></div>
Been there done that too. Make sure the bearings are preloaded correctly or it will grenade again
Old Dec 11, 2007 | 08:37 AM
  #15
blinim's Avatar
I was lucky then, caught mine when founds axle wobble. Thought it was bearing stuffed, but turned out to be simple case of axle nut loose.
When sorted make sure after any reasonable run that:
1. You grease bearing case (not too much as to make grease ooze out of seals - then lets water back in)
2. Check chain play is correct
3. Check torque on axle nut (remeber - left-hand trhead).
Good luck.
Old Dec 11, 2007 | 10:04 AM
  #16
I usually take pretty good car of my machine. It had been a while since I greased the bearing case because I've been doing a lot of long rides, so that might have been the problem. Or it could have just been old age. It's 7 years old, I expect things to go wrong like this. I ordered the bearings. When they come in I'll make sure someone gives me a detailes rundown of how to install them correctly.
Old Dec 20, 2007 | 10:01 AM
  #17
I got my bearing yesterday and went to the dealer to get the seals, so I'm ready to go. Can someone give me a basic run down on how to install these? Thanks.
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 13, 2015 05:11 PM
